contenderv07
Feb 06, 2020Aspirant
BGW210 ATT Fiber
Hey everyone, I just got an AC3000 and 2 satellites and I'm having some trouble getting connected. I informed ATT that I was moving from their wireless to the Orbi, and they said they would make chan...
Mar 05, 2020Guru - Experienced User
I would review this:
chiadisan wrote:Hi,
I'll be setting up a friend's Orbi with AT&T gateway tomorrow. I have one also. I've seen so many variants re: setup on this site so, I'll keep this simple.
*My setup at home is the att gateway BGW210 with WAP for U-VerseTV (IPTV). Orbi is plugged into gateway, of course, WAP is plugged into the gateway, works fine, never has any issues seen in other threads. orbi was always in Router mode. NO issues, other than TV stutters or freezes sometime, they all do *However, as a test, I did just leave the att gateway as-is and put the orbi into AP mode, all seems fine - though it was fine *before doing this.
Just looking a simple setup solution when doing my friend's same setup tomorrow. Am I missing a step re: gateway passthrough, etc?
Thanks!
chiadisan
Mar 05, 2020Aspirant
Thanks,
I have the native Ookla speed test app. My fiber 300 is about 370 up and down (ethernet) and near 200+ on Orbi WiFI.
Changing the Orbi to AP from Router hasn't afected speed - or anything esle.
- FURRYe38Mar 05, 2020Guru - Experienced User
You should be good to go then.
:smileywink:
