contenderv07
Feb 06, 2020Aspirant
BGW210 ATT Fiber
Hey everyone, I just got an AC3000 and 2 satellites and I'm having some trouble getting connected. I informed ATT that I was moving from their wireless to the Orbi, and they said they would make chan...
Mar 05, 2020Guru - Experienced User
:smileywink:
chiadisan
Mar 05, 2020Aspirant
Really, the only difference now since switching orbi to AP mode is 192.168 addressing.
All Apple network here + TVs, I liked the Orbi handing out 10.0.1 addressing. Going to leave it in AP mode tonight and check for any TV freezes. Other than that, I'll assume I can set up my friends as I had it, Router mode/ WiFi SSIDs off/ 10.0.1 addressing...
Glad I found this thread.
- FURRYe38Mar 06, 2020Guru - Experienced User
Yes you can use the 10.0.1 addressing scheme. Main the Orbi may use that if it detects the main host router or modem having the same default 192.168.1.1 address, so Orbi auto changes it's IP address to 10.0.1.1. However you can use this number if you want to even if your main host router or modem doesn't use 192.168.1.1.
Enjoy. :smileywink:
- chiadisanMar 06, 2020Aspirant
Yes, that's what I ended up doing. This Orbi 3-pack was the samller model, and the firmwares mut've been very old,
Orbi pitche a fit*every step of the process.. a few reboots, new FW, got them to all to behave in 10.0./ Router mode. This Orbi really didn't want to behave. Don't know how a regualr customer would ust plug them in & use the iphone app! Sheesh.
Thanks for the help. *I'll probably revert mine back to router/ 10.0. as well.
Have a good weekend.
Enjoy. :smileywink:
