Mpatriota
Oct 16, 2022Aspirant
Big house - Can I connect up to 20 satellites?
Guys, Can I use 20 satellites wired, no wifi backhand required. I have a huge house with concrete walls that require at least 20 satellites to handle all the floors. Anyone already tested?
schumaku
Oct 16, 2022Guru - Experienced User
What is the point of shopping into a an expensive, expansion limited mesh system supporting wireless backhaul in the first priority (apparently not what you need) if there is a wired LAN available, with a NAT router - either something fancy or the ISP provided router, some network switches serving the wired infrastructure links and ports, and a bunch of wireless access points like a some WAX6xx, which can ideally PoE+/PoE++ powered? A wide selection of switches and wireless access points is available https://www.netgear.com/business/services/insight/devices/ with a neat unified cloud management - the perfect fit for your existing infrastructure.
