Mpatriota
Oct 16, 2022Aspirant
Big house - Can I connect up to 20 satellites?
Guys, Can I use 20 satellites wired, no wifi backhand required. I have a huge house with concrete walls that require at least 20 satellites to handle all the floors. Anyone already tested?
Oct 16, 2022Guru - Experienced User
https://kb.netgear.com/000062035/How-many-satellites-can-you-add-to-an-Orbi-WiFi-System
Home systems are not designed for that kind of size and use. You'll need to look into a business class system instead.
schumaku
This KB also applies to the small consumer style MK60 and MK80 kits only. However, I would not go beyond these small numbers even on Orbi, Orbi WiFi 6, or Orbi 6 Pro configurations.
