Mpatriota
Oct 16, 2022Aspirant
Big house - Can I connect up to 20 satellites?
Guys, Can I use 20 satellites wired, no wifi backhand required. I have a huge house with concrete walls that require at least 20 satellites to handle all the floors. Anyone already tested?
Mpatriota
The owned wants a home solution without vlans. He just wants not a cheap but a simple solution to avoid misconfiguration due to complex setups. The house has 27000 sqft so using the air magnet suggested around 42 access points and I agree with you guys, a home solution will not the best solution but I must improvise.
schumaku
Oct 16, 2022Guru - Experienced User
With the suggested Netgear Insight solution, it can't be easier - even if you just need to deploys one (flat) network. You won't look back! No needs for improvisation - configure the Wi-Fi starting from one sample AP, then just plug the other AP to the network, and go.
