AzJazz
Jan 26, 2017Apprentice
Bizarre! Orbi sort-of loses configuration and won't let me log in
I just ran into a bizarre problem with my Orbi system this morning. My router/satellite are running v1.4.0.34. My main PC is running Win10x64. My ISP was doing work in my area, and my interne...
DarrenM
Jan 30, 2017Sr. NETGEAR Moderator
Hello AzJazz
Glad to hear a reset fixed the issue but let us know if something else comes up.
DarrenM
AzJazz
Jul 20, 2017Apprentice
Hi, DarrenM - I still run into this problem randomly, and it takes a really long time to get the Orbi functional again. I have seen this occur about a dozen times since I last posted
It happened to me again this morning. I was working on my PC this morning, and then suddenly ... BAM!! ... Nobody could connect to the WiFi in my house. I tried to go to the Orbi settings, and I kept getting prompted for my Username/Password. Eventually, I was asked for the Serial Number on the Orbi base. I was told that the LAN and Orbi Router IP address was automatically reconfigured to 10.0.0.1 "for my protection" (from 192.168.0.1). My main PC has a hard wire connection to the router, so I was eventually able to get it running again.
Is there anything I can do to fix this? If it happens when I am out of town, I won't be able reconfigure it remotely. My wife will probably divorce me.
Please save my marriage.
AzJazz
- DarrenMJul 21, 2017Sr. NETGEAR Moderator
Hello Azjazz
You may want to back up your config and do a factory reset the last update was a big one and changed alot of things.
DarrenM
- AzJazzJul 21, 2017Apprentice
Hi, DarrenM - I already have the latest firmware version installed (v1.12.0.18)
Are you saying that I need to wipe out all my current settings and reconfigure from scratch?
If "Yes", will I also have to wipe out my Orbi Satellite?BTW, is the problem I am describing in this thread a known Orbi issue? One thing I have noticed is that the problem seems to occur when my ISP goes dead for a while.
Thanks,
AzJazz
- DarrenMJul 25, 2017Sr. NETGEAR Moderator
Hello AzJazz
Yes that is what I am saying you can back up your config before doing this if you want to try and reload it.
DarrenM
- AniDuttaJul 21, 2017ApprenticeDarrenM: This happened to me too. This morning suddenly none of my devices would connect to wifi. Even hard wired devices connected to Orbi router wasn't working. Comcast wasn't down. I tried power cycle the Orbi to no help. Ultimately I factory reset and restored settings from backup config! This is second time this happened with most current firmware.
