shsabres
Dec 27, 2018Aspirant
Black Ops 4 PS4 Nat help
I just got my Orbi and hooked it up. I am a console gamer (PS4) and had NO ISSUES with my nat type until I got the orbi today.
Now my nat type is MODERATE.
I went online for the past THR...
Dec 27, 2018Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
uPnP is only needed for any game console. You don't need Port Forwarding configurations.
Also NAT Type 2 will be what the PS console will get behind any router connected to a modem only service.
NAT Type 1 is the PS console connected directly to the stand alone modem.
shsabres
v2.1.4.16_1.0.0.11
Verizon Fios Quantum Gateway G1100 Wireless Wi-Fi Router FiOS-G1100 Dual Band
- FURRYe38Dec 27, 2018Guru - Experienced User
Ok, your ISP Modem has a built in router already so this will be a cause of being in a double NAT condition.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
