awasen's avatar
awasen
Follower
Feb 24, 2018
"Blind spot" just between the two RBK50 router/satellite
First off, I am very pleased with the perfomance of the Orbi solution. I've tested a lot of different sytems, routes, extenders, etc. but have always ran into problems as I live in a house built with concrete...
The problem/question I have is if there is any way to "isolate" the WiFi client to a specific unit, eihter the Satellite or the Router. My dining room sits right between the two and I see problems with laptops, phones (both Andriod and iPhone) at two or three places around the table where the Internet access is flakey. The WiFi is a steady 5/5 but Internet goes on/off and doing a WiFi analysis I can see that the connection jumps between the sattelite and the router constantly and each jump causes a short Internet drop.
Is there some setting that will prioritize one specific unit or make them less "competitive"?
  • A potential fix is to simply move the satellites a few feet further away. Turning on "Fast Roaming" could provide a less competetive environment. Finally, decreasing the power output of either the 5 gHz or 2.4 gHz signals could also help. I'd advise only doing one of these at a time to see which results in the best connectivity. Sometimes finding the correct combination of satellite placement seems more like an art than science. Good luck!
  • FURRYe38's avatar
    I would disable the 2nd Satellite and test only with the main router and 1 Satellite and see how the system and devices work. I'm only using 1 Satellite and router in my 5000sq ft house. Performance and range is stellar.
