chrisxpierce
May 31, 2020Tutor
Blink XT2 Camera - Live View Issues?
Hi all, Does anyone have the Blink XT2 Camera's on the Orbi System? If so, are you having issues viewing Live Views? I had these camera's for months, and about 6 weeks ago, they started having...
- May 31, 2020
A couple things.
1. your firmware on the orbi's is out of date. you can manually update if the app or browser is telling you its current. just make sure to do the satellites first.
2. the arris sbg10 is a modem/router combo device. Which if you don't have the arris in bridge mode or the netgear in access point mode, would cause a double nat. which can cause issues such as your having.
https://kb.netgear.com/30186/What-is-Double-NAT
chrisxpierce
May 31, 2020Tutor
Orbi RBR40 - Firmware - V2.3.5.32
Arris Surfboard SBG10
Satelite 1 V2.3.5.6
Satelite 2 V2.3.5.6
Thanks
May 31, 2020Guru - Experienced User
A couple things.
