chrisxpierce
May 31, 2020Tutor
Blink XT2 Camera - Live View Issues?
Hi all, Does anyone have the Blink XT2 Camera's on the Orbi System? If so, are you having issues viewing Live Views? I had these camera's for months, and about 6 weeks ago, they started having...
- May 31, 2020
A couple things.
1. your firmware on the orbi's is out of date. you can manually update if the app or browser is telling you its current. just make sure to do the satellites first.
2. the arris sbg10 is a modem/router combo device. Which if you don't have the arris in bridge mode or the netgear in access point mode, would cause a double nat. which can cause issues such as your having.
https://kb.netgear.com/30186/What-is-Double-NAT
chrisxpierce
May 31, 2020Tutor
Just noticing that he satelites are both utilizing the 5ghz bands. and they're the ones connected to the blink cameras. don't know if that could be the problem...as the camera's are only 2.4ghz.
May 31, 2020Guru - Experienced User
chrisxpierce wrote:Just noticing that he satelites are both utilizing the 5ghz bands. and they're the ones connected to the blink cameras. don't know if that could be the problem...as the camera's are only 2.4ghz.
The satellites have both 2.4ghz and 5ghz and use both. It does band steering. I've got multiple cameras on mine that are only 2.4ghz. I'd be looking at the firmware and the double nat issue.
- chrisxpierceMay 31, 2020TutorAfter manually updating firmware, SO FAR SO GOOD. Live view issues appear to have cleared up. Thanks... I'll keep ya posted.
- samor23Jun 02, 2020Tutor
i just wanted to say i also have blink cameras and after the update my blink all worked. had issues for weeks
