dstrohmeyer's avatar
dstrohmeyer
Block Device Access with Orbi
Does anyone know if there is a way to simply block device access with the Orib?
It allows me to select "block" on the network map in the Genie App, but it does not seem to do anything. I bought this for increased parental controls as well as the network (great so far), but I would like to be able to block something when needed.
Thanks
DS
1 Reply
  • The block works for me using the Genie app and also through the Orbilogin.com option on iOS devices. I'm on the most current firmware.
