chivolet's avatar
chivolet
Block services not working
  If I go into my RBR50 Orbi router under block services, and select thhe defaults of VPN-IPSEC, VPN-L2TP, VPN-PPTP, IPsec, and then add some addition ones such as tcp/udp ports 1194 that should prev...
  • CrimpOn's avatar
    CrimpOn
    Feb 09, 2021
    chivolet wrote:
    Thanks CrimpOn for attempting to recreate it.  Not sure how you captured the Wan/Lan traffic unless you did it off of a switch.
    Although I have no solution to the problem, at least I can explain how to capture LAN/WAN traffic.
    On the Orbi debug page (http://orbilogin.net/debug.htm) there is a check box to "Enable LAN/WAN packet capture".
    Then, click on "START CAPTURE". Perform whatever tests you want.  Then click on "SAVE DEBUG LOG".
    This will create a file in the PC Download folder called Debug.zip that has all sorts of stuff in it.  The files I want are LAN.pcap and WAN.pcap which can be opened by a lot of networking programs.  I use Wireshark (a) because it's free, and (b) because it has a lot of display filter options.
