chivolet
Feb 02, 2021Aspirant
Block services not working
If I go into my RBR50 Orbi router under block services, and select thhe defaults of VPN-IPSEC, VPN-L2TP, VPN-PPTP, IPsec, and then add some addition ones such as tcp/udp ports 1194 that should prev...
- Feb 09, 2021
chivolet wrote:Thanks CrimpOn for attempting to recreate it. Not sure how you captured the Wan/Lan traffic unless you did it off of a switch.
Although I have no solution to the problem, at least I can explain how to capture LAN/WAN traffic.
On the Orbi debug page (http://orbilogin.net/debug.htm) there is a check box to "Enable LAN/WAN packet capture".
Then, click on "START CAPTURE". Perform whatever tests you want. Then click on "SAVE DEBUG LOG".
This will create a file in the PC Download folder called Debug.zip that has all sorts of stuff in it. The files I want are LAN.pcap and WAN.pcap which can be opened by a lot of networking programs. I use Wireshark (a) because it's free, and (b) because it has a lot of display filter options.
CrimpOn
Feb 02, 2021Guru - Experienced User
chivolet wrote:If I go into my RBR50 Orbi router under block services, and select thhe defaults of VPN-IPSEC, VPN-L2TP, VPN-PPTP, IPsec, and then add some addition ones such as tcp/udp ports 1194 that should prevent any VPN from being established but it does not. Is this a known issue that the option is there but it doesn't work? I am on version V2.5.2.4
Thanks in advance,
Having no VPN, I performed a block on telnet (port 23). After verifying that my PC could telnet to lord.stabs.org (no idea what it is, but was on a list of "places to telnet"), I set up a block on telnet for my PC. After 'Adding' the block and clickiing 'Apply', telnet would no longer open a connection. After removing the service block, telnet works again. I should confess that in the past I have been in a hurry and neglected to click 'Apply' or did not notice that although I set the service block to "Always", it got put back to "Never" and I had basically applied nothing. For me, User Error is a daily occurance.
Conclusion: Blocking VPN may not be as simple as blocking telnet. What I would do is collect the Orbi WAN/LAN traffic while opening a VPN session and see where it goes and what ports are being used.
chivolet
Feb 09, 2021Aspirant
Thanks CrimpOn for attempting to recreate it. Not sure how you captured the Wan/Lan traffic unless you did it off of a switch. My Orbi doesn't give you that option other then grabbing logs for "Attempted access to blocked sites and services". The log did show it was blocking the VPN but I was still able to establish a VPN and go wherever I wanted to go using global protect, pulse secure, and HOXX vpn. Tunnelblick seems to be the only one that stopped working. I have added as many TCP/UDP ports I can find to put in the services, I have tried the services blocking on always, per schedule, turned it off and then back on. I just updated to the latest code thinking it may be a code issue but nothing has changed. I don't think this box fully supports blocking services even though it is listed in the documentation for VPNs.
I ran through your test with telnet and had the same finding. That does work like a champ.
