bevanmission
Mar 09, 2021Aspirant
block wifi channel from neighbors
Is there any way for me to choose my channels for my 2.4, and two 5.2 wifi connections AND then block my neighborhood from accessing the same channels that I'm using?? I have 1Gig wired internet ...
Mar 09, 2021Guru - Experienced User
You can change channels on the RBRs web page using a web browser.
No you can't block other wifi signals from using the same channel. However you can try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
