Bfarr76
Jul 29, 2023Follower
Blocked devices
Hi,
I was wondering if i blocked a device while its connected to my WI-FI once they disconnect their device will they be able to connect at a later time or will they still be blocked from connecting.
1 Reply
More information would be helpful:
Blocking the device how?
- Using a feature of Parental Controls?
- Using the pause slider in the Orbi 'app'?
- Using the Orbi web interface, Advanced Tab, Security menu Access Control page to define the hardware MAC address as Blocked?
The obvious answer is, "of course." Block something, and it stays blocked until you deliberately unblock it.
Why not try an experiment? Pick some device that is not particularly important right this second, block it, then wait an hour and try to connect it again. (Maybe an Amazon Fire tablet, smart plug, smart light bulb, etc.
If the device changes WiFi MAC address, then my guess is that the Orbi will not recognize it as 'blocked'.
