atleasttwochara
Aug 10, 2020Aspirant
Blocked Service but imessage goes through
I've blocked services on a schedule and it blocks web browsing but imessage still work. How can stop all services?
atleasttwochara
Aug 11, 2020Aspirant
my netgear product is actuall RBR10 dual band system but wasnt in drop down. Devices affected are wi-fi only ipads and are able to text even though services are blocked.
Mstrbig
Aug 11, 2020Master
atleasttwochara wrote:my netgear product is actuall RBR10 dual band system but wasnt in drop down. Devices affected are wi-fi only ipads and are able to text even though services are blocked.
When you say text, are you referring to Apple's communications system, like Facetime, Imessage, etc?
If so these are the ports open. Possibly blocking these will give you the results you need.
FaceTime:
80 (TCP), 443 (TCP), 3478 through 3497 (UDP), 5223 (TCP), 16384 through 16387 (UDP), 16393 through 16402 (UDP)
iMessage:
80 (TCP), 443 (TCP), 5223 (TCP)
- atleasttwocharaAug 13, 2020Aspirant
I have it set for:
Under: Blocked Services Setup
Service Type = Any
Protocol = TCP/UDP
