Maryann972
Dec 08, 2020Aspirant
Blocked sites
Why are many sites blocked with 404 Not found! So very frustrating to view recipes & shop.
Dec 08, 2020Guru - Experienced User
So what product are you referring too?
michaelkenward
Dec 09, 2020Guru - Experienced User
And where do you see these messages?
A browser? Which one?
- plemansDec 09, 2020Guru - Experienced User
As michaelkenward FURRYe38 have implied, more details are needed.
What modem/gateway do you have?
What router is it connected to?
Firmware on the router?
do all devices have this issue? or just one?
- Maryann972Dec 09, 2020AspirantMost sites are blocked stating 404-file or directory not found. This new router is blocking everything!
And you didn't answer a single answer above. We can't help you without details.
If you just bought it, you can contact support. You have support free for the first 90 days of purchase (if new).
click on "mynetgear' register an account and the device. from there you can contact support.
