Maryann972
Dec 08, 2020Aspirant
Blocked sites
Why are many sites blocked with 404 Not found! So very frustrating to view recipes & shop.
michaelkenward
Dec 09, 2020Guru - Experienced User
And where do you see these messages?
A browser? Which one?
As michaelkenward FURRYe38 have implied, more details are needed.
What modem/gateway do you have?
What router is it connected to?
Firmware on the router?
do all devices have this issue? or just one?
- Maryann972Dec 09, 2020AspirantMost sites are blocked stating 404-file or directory not found. This new router is blocking everything!
- plemansDec 09, 2020Guru - Experienced User
And you didn't answer a single answer above. We can't help you without details.
If you just bought it, you can contact support. You have support free for the first 90 days of purchase (if new).
click on "mynetgear' register an account and the device. from there you can contact support.
- michaelkenwardDec 09, 2020Guru - Experienced User
Maryann972 wrote:
Most sites are blocked stating 404-file or directory not found. This new router is blocking everything!Sounds like you have a problem with this technology stuff.
If you can't find the answers to the questions that people have asked you – there are plenty more where they came from – I suggest that you return the thing to whoever supplied it and buy something else.
Explain your problem to them and they may offer an easier alternative
- FURRYe38Dec 09, 2020Guru - Experienced User
