Maryann972
Dec 09, 2020Aspirant
Blocked sites
Why are many sites blocked with 404 Not found! So very frustrating to view recipes & shop.
Maryann972
Most sites are blocked stating 404-file or directory not found. This new router is blocking everything!
michaelkenward
Dec 09, 2020Guru - Experienced User
Sounds like you have a problem with this technology stuff.
If you can't find the answers to the questions that people have asked you – there are plenty more where they came from – I suggest that you return the thing to whoever supplied it and buy something else.
Explain your problem to them and they may offer an easier alternative
