Allenmccloud
Aug 26, 2019Aspirant
Blocked web sites on mobile but not on mac
Since installing my Orbi I cant access some web sites on my mobile iphoneX. On my Mac its ok but on phone blocked. I have checked both phone and Orbi for child safety and everything is off so can't u...
Aug 26, 2019Guru - Experienced User
Have you setup any IP address reservations for the Mac and iPhone?
Have you enabled any Circle or Armor freatures on the RBR when you first set it up?
Allenmccloud wrote:Since installing my Orbi I cant access some web sites on my mobile iphoneX. On my Mac its ok but on phone blocked. I have checked both phone and Orbi for child safety and everything is off so can't understand. If I go to another wifi spot I can access but not at home. Any one help? Allen
Allenmccloud
Aug 27, 2019Aspirant
Looks like I have done it. I went on to orbi log in and activated Standard Parental Controls. It seems its the wrong way around when its on its clear when its off it stops sites.
- FURRYe38Aug 27, 2019Guru - Experienced User
What mode is your VirginHub3 running in? Router mode or modem only mode?
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router"It seems its the wrong way around when its on its clear when its off it stops sites." What do you mean by this?
Allenmccloud wrote:Looks like I have done it. I went on to orbi log in and activated Standard Parental Controls. It seems its the wrong way around when its on its clear when its off it stops sites.
