lebphi
Aug 16, 2019Aspirant
blocker les ports sur orbi rbk23
bonjour, j'envisage d'acheter un pack orbi rbk23 mais avant je voudrais savoir s'il est possbile de bloquer les ports en sortie. Je voudrais en fait bloquer par défaut tous les ports à l'except...
lebphi
I plan to buy a pack orbi rbk23 but before I would like to know if it is possbile to block the ports output.
I would like to block all ports except for a few (80, 443, ...).
I looked in the doc but did not find how to do it.
Is it possible ?
thank you in advance
Aug 16, 2019Guru - Experienced User
I don't believe blocking ports is a feature of Orbi. You can block devices.
You could I support do Port Forwards to a phantom IP address if you really need to block ports.
- lebphiAug 17, 2019Aspirant
thanks you.
I wanted to replace my 2 mikrotik router by a mesh solution but the orbi isn't enough customizable for me. I would like a solution with iptables possibilities.
