Sam_C
Sep 20, 2023Aspirant
Blocking guest wireless access to 1 device only on network
Hi, I have a ORBI RBK50 Router and 1 Satellite unit with latest firmware. For Guest wireless access, I want to bloc access to my NAS, whilst keep access to other devices like a printer and various m...
Sep 20, 2023Guru - Experienced User
Normally GN access to LAN side resources is blocked by default. I thought this was the case for the 50 series. I haven't had mine online in a while. There is no WEB UI option for blocking or unblocking GN access I believe, if you don't see anything on the WEB UI, it would be blocked by default.
Though I see that there maybe a check box here that allows GN access to LAN side sources:
What FW version are you using?
Sam_C
Sep 22, 2023Aspirant
FW version is V2.7.4.24 on both the Router and Sat. Thanks
