ToddK963
Aug 29, 2020Follower
Boosting the Range of WiFi
I own an Orbi RBR50 router as well as a RBS50 satellite. My WiFi signal is not reaching all parts of the house with sufficient strength. Do I need to buy an additional RBS 50 or will another Orbi p...
CrimpOn
Aug 29, 2020Guru - Experienced User
ToddK963 wrote:I own an Orbi RBR50 router as well as a RBS50 satellite. My WiFi signal is not reaching all parts of the house with sufficient strength. Do I need to buy an additional RBS 50 or will another Orbi product -- such as at Orbi AC 2200 Wall Plug satellite -- work as well? I want to make sure I buy something compatible with the router.
Every satellite in the "original Orbi" line is compatible with the RBR50 router except the RBS10 (the least expensive and most available)
RBS50, RBS40, RBS20, RBW30, RBS50Y (outdoor)
Other Orbi product lines are not compatible: Orbi "Pro". Orbi AX.
