ToddK963
Aug 29, 2020Follower
Boosting the Range of WiFi
I own an Orbi RBR50 router as well as a RBS50 satellite. My WiFi signal is not reaching all parts of the house with sufficient strength. Do I need to buy an additional RBS 50 or will another Orbi p...
Mstrbig
Aug 29, 2020Master
ToddK963 wrote:I own an Orbi RBR50 router as well as a RBS50 satellite. My WiFi signal is not reaching all parts of the house with sufficient strength. Do I need to buy an additional RBS 50 or will another Orbi product -- such as at Orbi AC 2200 Wall Plug satellite -- work as well? I want to make sure I buy something compatible with the router.
Your decision should be based on how much more coverage you need or want. The RBS50 satellite will give you better coverage and wireless backhaul speed over RBS40, RBS30, RBS20 and a wall plug satellite. But if you want to save some money and get almost as good coverage, the Orbi RBS40V is on sale right now for $99.00US, https://www.netgear.com/orbi/rbs40v-200.aspx.
