ds1664
Jan 19, 2020Aspirant
Bose soundtouch stops streaming when large data files are transferred over the network
I have just purchased a Orbi RBR50 system including two satellites. The router is connected to a Virgin media Hub 3 running in modem mode. I have a server connected which is a wired connection direct...
CrimpOn
Jan 19, 2020Guru - Experienced User
ds1664 wrote:I have just purchased a Orbi RBR50 system including two satellites.
Are you ever in luck. Netgear provides 90 days of "complimentary support" starting when a new system is registered. On the registration web page, there is a link to contact support. This looks like an excellent problem to discuss with them.
ds1664 wrote:I have read that the orbi puts priority on music packets .. is that correct ?
I have heard that when Orbi originally came out there was a menu selection for QoS, which has since disappeared, perhaps because it did not work well. I do not recall ever seeing it myself. There are Orbi parameters with "qos" in the description that seem to indicate qos, but I have no idea (a) how to interpret them, or (b) if they are actually used for anything. What is pretty clear is that qos operates by UDP/TCP port number (see attachment). So, "music" is not a useful descriptor. (I did not see any parameter with "Bose" in the title.)
ds1664 wrote:What options do I have to improve the system, apart from stop sending large files :) and using wired connection my PC which is not possible
Perhaps there is a method to "rate limit" file sending on the PC? Perhaps lower the priority of the process? You might also research which frequencies Bose uses, and if it sets up a separate WiFi network internal to the Bose products. I seem to recall reading posts about other speaker systems which operate in the 5G band and sometimes conflict with 5G WiFi networks. If so, there might be a way to connect the data link at only 2.4G and thus avoid stressing the 5G band. Or, perhaps select a 5G channel which will interfere less with the Bose product.
I have always wanted the opportunity to contact Netgear support. My Orbi was nearly a year old before I had occasion to ask a question, which led me to this community forum.
