ds1664
Jan 19, 2020Aspirant
Bose soundtouch stops streaming when large data files are transferred over the network
I have just purchased a Orbi RBR50 system including two satellites. The router is connected to a Virgin media Hub 3 running in modem mode. I have a server connected which is a wired connection direct...
Dfran1
Jan 20, 2020Apprentice
Hi,
did you update firmware?
I had major problems after updating firmware, nothing seemed to work..
i sold the old orbi to someone that did not need the satellite. Orbi router is working great for them, so this hopefully fix below will work for you.
i then purchased another orbi system, locked the firmware down at 2.1.4.16
and never had a problem to date, I can stream and download at the same time with no problems. As before I could not, and had WiFi problems all the time with multiple uses at once, very similar to yours.
I did find something you can try after I continued to try to track this problem down just in case I took an update somehow.....
try this...
1. remove the satellites From the router in software, I can't seem to find out how, maybe shut down the satellite and a remove pops up, sorry but it has been a long time now since I had to play around with this and I know I had saw this in the menu somewhere.. maybe some will chime in on where to find this?
2. after you remove the satellites, reboot the router
3. factory default the satellites
4. then add the satellites back.
if this works or not please post back here.
