anthonymoody
Jul 27, 2019Aspirant
Both satellites connected via ethernet, but one shows as wired, one shows as wireless
I have an RBR50 and two RBS50s. Everything worked great for months with wired ethernet backhaul. Then one of the RBS50s died. Received a replacement via RMA. Set it up wirelessly, and after a couple ...
- Jul 28, 2019
- From the picture you posted (attached in my post here), it seems that Daisy Chain is enabled. Please uncheck it in the web GUI. It has to be unchecked in your case
- Have you tried the procedure I described in my previous post? That is to Factory reset the Satellite and sync it only when it's wired to the Router, don't sycn the Satellite with wireless backhaul at all.
Jul 27, 2019Guru - Experienced User
Is Daisy Chain enabled? Disable DS if it is...
Using v30 FW on everything?
Turn OFF the working RBS and see if you can get the 2nd RBS working first.
Give the system time to settle in before checking the status...
anthonymoody wrote:I have an RBR50 and two RBS50s. Everything worked great for months with wired ethernet backhaul. Then one of the RBS50s died. Received a replacement via RMA. Set it up wirelessly, and after a couple of attempts got it working and connected wirelessly. Then connected the ethernet cable to it. But both the iOS app and the orbilogin page still shows the new/replacement RBS50 as wireless (5G) rather than wired. That's the same sequence I used when I first set the system up: got it working wirelessly, then connected satellites via ethernet and they grabbed IPs over the wire. Now, I can't seem to 'force' it over to wired. Tried to re-sync and no joy. Tried enabling and disabling the Daisy Chain option, still no joy. The original, still-functioning RBS50 is still showing wired. All three units show up to date as far as firmware.
Thoughts?
- anthonymoodyJul 27, 2019Aspirant
Thanks.
-Daisy Chain is currently enabled (box is checked) but what is DS?
-On 2.3.5.30 on all 3 devices
I'll wait for your response on DS and see if you have any other thoughts before I try turning off the working RBS...TIA.
FURRYe38 wrote:Is Daisy Chain enabled? Disable DS if it is...
Thoughts?
- FURRYe38Jul 27, 2019Guru - Experienced User
OOps was a typo. Sorry. Supposed to be DC=Daisy Chain.
Daisy Chain needs to be disabled for RBS wired connections.
Thanks. Ok I've disabled it again. Going to give the RBS50 a bit of time to see if it'll magically grab an IP over wired before turning off the working RBS50 (about which, not sure why that would have any impact on the other but...ok I guess!)
FURRYe38 wrote:OOps was a typo. Sorry. Supposed to be DC=Daisy Chain.
