anthonymoody
Jul 27, 2019Aspirant
Both satellites connected via ethernet, but one shows as wired, one shows as wireless
I have an RBR50 and two RBS50s. Everything worked great for months with wired ethernet backhaul. Then one of the RBS50s died. Received a replacement via RMA. Set it up wirelessly, and after a couple ...
- Jul 28, 2019
- From the picture you posted (attached in my post here), it seems that Daisy Chain is enabled. Please uncheck it in the web GUI. It has to be unchecked in your case
- Have you tried the procedure I described in my previous post? That is to Factory reset the Satellite and sync it only when it's wired to the Router, don't sycn the Satellite with wireless backhaul at all.
ekhalil
Jul 28, 2019Master
anthonymoody wrote:............ Set it up wirelessly, and after a couple of attempts got it working and connected wirelessly. Then connected the ethernet cable to it. But both the iOS app and the orbilogin page still shows the new/replacement RBS50 as wireless (5G) rather than wired. ..........
I think there is something changed in 2.3.5.30 (and probably earlier packages as well) regarding wired backhaul.
If you want to use wired backhaul then you SHOULD NOT sync the Satellite using wireless backhaul first and then connect the wires. The Satellite should be synced only once using wired backhaul
Please factory reset the satellite (using a pinclip and hold for 10 seconds), go into web GUI "Attached Devices" and click on "Disconnect" the Satellite.
Now sync the Satellite while wired to the Router.
See if this will give you better results. :)
- anthonymoodyJul 28, 2019Aspirant
Thanks. Unfortunately that didn't work. It sync'd but again as wireless. I wonder though if I somehow didn't do a total factory reset as the device shows up again with the name I gave it, rather than the generic out of the box designation, i.e. it's called Kids Playroom rather than Orbi-sat2 or whatever. Did I not get the factory reset correct? I thought I had since the web interface did give me the option to Remove it, which I did as you recommended. Thoughts?
(btw I also tried what the other person suggested, but the power on/off condition of the working wired satellite didn't seem to make a difference)
Hmm, well, I tried it one more time and got a strange result. The web interface says it sync'd successfully, the dashboard shows it connected as Wired, BUT, the iOS app shows it daisy chained via my other satellite, wirelessly (dotted line) and magenta. And the satellite itself is pulsing white. I'm inclined to 'beleive' the iOS app since the satellite is pulsing white and not off. BTW, the satellite *never* went to solid white to prompt me to sync - it kept pulsing white. I did the sync anyway after several minutes via the web as I said, and the web said it worked, but....?
As suspected, iOS was right and the web interface was wrong. iOS still showing this screenshot iOS screenshot (now amber, not magenta) and web interface showing 5G with status as Config Sync. Frustrating.
Well, I tried it again, this time with the Daisy Chain box unselected (I've seen some speculation that this toggle is backward), and things returned to my first problematic state i.e. in hub/spoke, one sat wired, the other sat wireless, both sats showing Good for backhaul status. And iOS seems to match the web interface.
Going in circles here :(
- ekhalilJul 28, 2019Master
It's weird - I thought I had Unchecked DC to try that, but when I went to the screen for that it was checked, as if somewhere along the way it'd turned itself back on. Well, I've now unchecked it which reboots the router, and confirmed that the DC box is unchecked. Then tried again with the sat as you descirbed. Reset, removed, and set up the satellite while wired, and LO AND BEHOLD, it WORKED!!
Thanks so much - deeply appreciated. I thought I had tried this but somehow the DC box was set opposite from how I thought it'd been set.
Anyway - you're right - set up WHILE WIRED, DC UNchecked. Thanks again!
