anthonymoody
Jul 27, 2019Aspirant
Both satellites connected via ethernet, but one shows as wired, one shows as wireless
I have an RBR50 and two RBS50s. Everything worked great for months with wired ethernet backhaul. Then one of the RBS50s died. Received a replacement via RMA. Set it up wirelessly, and after a couple ...
- Jul 28, 2019
- From the picture you posted (attached in my post here), it seems that Daisy Chain is enabled. Please uncheck it in the web GUI. It has to be unchecked in your case
- Have you tried the procedure I described in my previous post? That is to Factory reset the Satellite and sync it only when it's wired to the Router, don't sycn the Satellite with wireless backhaul at all.
ekhalil
Jul 28, 2019Master
anthonymoody wrote:............ Set it up wirelessly, and after a couple of attempts got it working and connected wirelessly. Then connected the ethernet cable to it. But both the iOS app and the orbilogin page still shows the new/replacement RBS50 as wireless (5G) rather than wired. ..........
I think there is something changed in 2.3.5.30 (and probably earlier packages as well) regarding wired backhaul.
If you want to use wired backhaul then you SHOULD NOT sync the Satellite using wireless backhaul first and then connect the wires. The Satellite should be synced only once using wired backhaul
Please factory reset the satellite (using a pinclip and hold for 10 seconds), go into web GUI "Attached Devices" and click on "Disconnect" the Satellite.
Now sync the Satellite while wired to the Router.
See if this will give you better results. :)
anthonymoody
Jul 28, 2019Aspirant
Hmm, well, I tried it one more time and got a strange result. The web interface says it sync'd successfully, the dashboard shows it connected as Wired, BUT, the iOS app shows it daisy chained via my other satellite, wirelessly (dotted line) and magenta. And the satellite itself is pulsing white. I'm inclined to 'beleive' the iOS app since the satellite is pulsing white and not off. BTW, the satellite *never* went to solid white to prompt me to sync - it kept pulsing white. I did the sync anyway after several minutes via the web as I said, and the web said it worked, but....?
