anthonymoody
Jul 27, 2019Aspirant
Both satellites connected via ethernet, but one shows as wired, one shows as wireless
I have an RBR50 and two RBS50s. Everything worked great for months with wired ethernet backhaul. Then one of the RBS50s died. Received a replacement via RMA. Set it up wirelessly, and after a couple ...
- Jul 28, 2019
- From the picture you posted (attached in my post here), it seems that Daisy Chain is enabled. Please uncheck it in the web GUI. It has to be unchecked in your case
- Have you tried the procedure I described in my previous post? That is to Factory reset the Satellite and sync it only when it's wired to the Router, don't sycn the Satellite with wireless backhaul at all.
ekhalil
Jul 28, 2019Master
anthonymoody wrote:............ Set it up wirelessly, and after a couple of attempts got it working and connected wirelessly. Then connected the ethernet cable to it. But both the iOS app and the orbilogin page still shows the new/replacement RBS50 as wireless (5G) rather than wired. ..........
I think there is something changed in 2.3.5.30 (and probably earlier packages as well) regarding wired backhaul.
If you want to use wired backhaul then you SHOULD NOT sync the Satellite using wireless backhaul first and then connect the wires. The Satellite should be synced only once using wired backhaul
Please factory reset the satellite (using a pinclip and hold for 10 seconds), go into web GUI "Attached Devices" and click on "Disconnect" the Satellite.
Now sync the Satellite while wired to the Router.
See if this will give you better results. :)
anthonymoody
Jul 28, 2019Aspirant
As suspected, iOS was right and the web interface was wrong. iOS still showing this screenshot iOS screenshot (now amber, not magenta) and web interface showing 5G with status as Config Sync. Frustrating.
