Topher44
Feb 10, 2020Tutor
Bought my Orbi secondhand, need to register it as mine
So just got my Orbi and need to register it under my own info. Is there a work around if I contact the seller and they don't do anything? How can I prove that I own it now and can therefore register it to me and input my own wifi info?
You don't need to register it to set it up or use it.
It mainly helps for using support or notices for firmware updates.
https://kb.netgear.com/1160/NETGEAR-Product-Registration-FAQ
- Topher44TutorI wouldn't need it registered to change the wifi name via the Orbi app?
Topher44 wrote:
I wouldn't need it registered to change the wifi name via the Orbi app?Nope.
I would recommend factory resetting to remove any of the prior owner's settings. You can do this by pushing and holding reset for 7-15 seconds while the orbi is powered up.
And then going through the setup process.
