Vivek12
Sep 21, 2020Follower
Bought RBK50 and RBS50v2 but extremely poor performance from Satellite.Months spent and case closed!
Hi, Bought RBK50 and Satellite RBS50 for my 1000 sq feet apartment, from the time of installation the satellite never delivered good performance. Opened a case with Netgear which was so painful, ever...
Sep 21, 2020Guru - Experienced User
If your home is 1000sq ft, then the RBS may not be needed. Turn OFF the RBS and set the RBR alone.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Also try turning down the power output of the RBRs wifi radios from 100% to 50% and see if this changes anything. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
