Whdj
Dec 05, 2021Aspirant
Bought used orbi
Hi, when I go to security in the app, it says the unit is still registered under previous owner and I can't login to netgear armor. How do I change this?
norwood
Dec 06, 2021Aspirant
You can return the Orbi Pro WiFi 6 to its factory settings. Use the end of a paper clip or a similar object to press and hold the Reset button located on the back of the Orbi for at least seven seconds. The Orbi resets and returns to the factory settings.
- WhdjDec 06, 2021Aspirant
That does reset the unit, but unfortunately doesn't apply to the netgear armor feature that's online
- FURRYe38Dec 06, 2021Guru - Experienced User
YOu may need to contact NG support and ask them for help and information regarding Armor. After the reset, just don't enabled Armor.
If you want Armor, it should allow you to setup a new account. Something to ask NG support about.
- WhdjDec 06, 2021AspirantIf I choose not to use armor, can he potentially see my new router and traffic if I just leave it as his email address? I've never used armor before.
