Whdj
Dec 05, 2021Aspirant
Bought used orbi
Hi, when I go to security in the app, it says the unit is still registered under previous owner and I can't login to netgear armor. How do I change this?
Dec 06, 2021Guru - Experienced User
YOu may need to contact NG support and ask them for help and information regarding Armor. After the reset, just don't enabled Armor.
If you want Armor, it should allow you to setup a new account. Something to ask NG support about.
Whdj
Dec 06, 2021Aspirant
If I choose not to use armor, can he potentially see my new router and traffic if I just leave it as his email address? I've never used armor before.
- CrimpOnDec 06, 2021Guru - Experienced User
Whdj wrote:
If I choose not to use armor, can he potentially see my new router and traffic if I just leave it as his email address? I've never used armor before.After you reset the Orbi, the previous owner totally loses the ability to connect to it. The major issue is the (gol-darn) Orbi 'app'. The app uses the MyNetgear login which belongs to the previous owner and (I believe) is also tied to the router serial number. So, he is now locked out, but neither of you can replace the entry in MyNetgear. That's why people who want to use the app have to plead their case with a forum moderator who can then contact someone internal at Netgear to modify the information. Bloody nuisance.
