jvegasatx
Jun 17, 2019Aspirant
BR20 Phone Connection Issues after 2.3.1.58 Upgrade
I have not been able to connect to my Orbi wireless LAN on a smart phone (both Samsung and iPhone) since upgrading to the v2.3.1.58 firmware. The logs show DOS Attack: ARP Attack when trying to conn...
Jun 18, 2019Guru - Experienced User
Try a factory reset on the RBR and setup from scratch.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?
jvegasatx wrote:I have not been able to connect to my Orbi wireless LAN on a smart phone (both Samsung and iPhone) since upgrading to the v2.3.1.58 firmware. The logs show DOS Attack: ARP Attack when trying to connect. Connecting PCs are not an issue.
jvegasatx
Jun 18, 2019Aspirant
Thanks for the reply!
I performed the factory reset, downgraded firmware to 2.3.1.48, set 2.4 to 11, changed to long preamble, set 2.4 to 25%, and disabled daisy chain. so far it has kept the connection for about 3 hours. i haven't noticed when the wireless connection to smart phones begins to drop so i am now trying to keep track of how long it maintains connection.
- FURRYe38Jun 18, 2019Guru - Experienced User
Try the reset and same configuration when you upgrade to v58 at some point.
