bradykp
Sep 21, 2020Follower
Brand New Orbi (AC2200 router + 1 satellite) - FIOS Quantum - Setup worked, but 10th device won't...
So I set up my Orbi plugged into the FIOS modem/router. So I have 2 "routers". I wanted the Orbi specifically for the Circle parental controls during virtual learning so I could block YouTube/enable ...
Sep 21, 2020Guru - Experienced User
Do if you disconnect ALL other wifi devices from the Orbi wifi, does the one laptop connect at all?
Make sure your one device doesn't have any static IP addressing configured on the device.
Be sure Circle isn't blocking the one device as well. Disable Circle to test this.
What mode is your ISP modem working in? Router or Modem only?
Having a router at the modem can be problematic. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
