Serafin630
Mar 16, 2021Tutor
BRB50 loses WIFI internet after firmware update
My RBR50 that has been humming along for 2.5+ years has suddenly sporadically losing the ability to provide internet connectivity. The problem started after I applied the most recent firmware update. ...
Musashi_Vega
May 18, 2021Aspirant
Hi I have exactly the same issue, did you find a solution?
- CrimpOnMay 23, 2021Guru - Experienced User
When problems come up immediately after installing new firmware, it might be time to consider downloading the previous firmware from the Netgear support site and manually installing it.
- FURRYe38May 23, 2021Guru - Experienced User
One thing to try after a FW update is power off for 1 minute then back ON with the ISP modem/ONT and Orbi system.
Or try a factory reset and setup from scratch on the RBR, with powering off the ISP modem/ONT for 30 seconds then back ON.
Musashi_Vega wrote:Hi I have exactly the same issue, did you find a solution?
- Serafin630May 24, 2021TutorI did a hard reset on the Satellite and stopped dropping WIFI completely but it still goes in and out. Orbi was good while it lasted but I think that it's time to move on
- FURRYe38May 24, 2021Guru - Experienced User
A reset on the RBR would be needed as well as the RBS.
Good Luck.
