Serafin630
Mar 16, 2021Tutor
BRB50 loses WIFI internet after firmware update
My RBR50 that has been humming along for 2.5+ years has suddenly sporadically losing the ability to provide internet connectivity. The problem started after I applied the most recent firmware update. ...
Musashi_Vega
May 18, 2021Aspirant
Hi I have exactly the same issue, did you find a solution?
CrimpOn
May 23, 2021Guru - Experienced User
When problems come up immediately after installing new firmware, it might be time to consider downloading the previous firmware from the Netgear support site and manually installing it.
