Serafin630
Mar 16, 2021Tutor
BRB50 loses WIFI internet after firmware update
My RBR50 that has been humming along for 2.5+ years has suddenly sporadically losing the ability to provide internet connectivity. The problem started after I applied the most recent firmware update. ...
Serafin630
May 24, 2021Tutor
I did a hard reset on the Satellite and stopped dropping WIFI completely but it still goes in and out. Orbi was good while it lasted but I think that it's time to move on
May 24, 2021Guru - Experienced User
A reset on the RBR would be needed as well as the RBS.
Good Luck.
