pmsurveys
Oct 20, 2019Aspirant
Bricked RBK50 Can’t get support for Ireland
Orbi RBK50 gave me problems this morning. Thought internet was down and with a few checks and trying my spare router I came to the conclusion that there was an issue with the RBK50. I tried logging i...
ekhalil
Oct 20, 2019Master
I think the best way is to use MyNETGEAR https://www.netgear.com/mynetgear/
After you login select My Support then CONTACT SUPPORT. One of the options you will then see is "Replace my defective product", click it and select the registered product you want help with.
Good luck.
- pmsurveysOct 20, 2019Aspirant
Thanks ekhalil did that earlier and that's when it gave me a case number and a phone number to call within 24 hours. The phone number it gave me doesn't work. It's been discussed here previously. So I'm trying to either get a number to call for the RMA (that they won't try and charge me for the call which happened earlier) or a contact name / email to progress the RMA.
I've seen other people get an answer through here so hopefully I can as well.
Thanks though for your help. Much appreciated.
