pkeisar
Aug 31, 2019Aspirant
Bricked RBR20
Hi all, my RBR20 is bricked after a firmware update. There is no WiFi network available, local ethernet and internet ports are down (no link) and it does not respond to Reset (long press, long press ...
pkeisar
Sep 01, 2019Aspirant
As I said - both ports are down, so I cannot connect to LAN for tftp...
Sep 01, 2019Guru - Experienced User
Did you try?
you're not the first with this issue.
https://community.netgear.com/t5/Orbi/Orbi-Satellite-corrupt-firmware/m-p/1636597
