Dcalaf
Jan 04, 2022Aspirant
Bricked RBR40
(Chose RBR50 in the model field, because RBR40 was not in the list) Hi, My RBR40 won't boot anymore. The power led remains green whatever the action on the reset button, and no upper led is ever...
- Jan 04, 2022
Unfortunately…
Thanks for your help !
Eric
Jan 04, 2022Guru - Experienced User
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Try nmrpflash:
https://github.com/jclehner/nmrpflash
- DcalafJan 04, 2022Aspirant
Thanks for your answer.
I tried this reset procedure already. However, the led remains steady green, and the ethernet ports keep off.
