Ryanwalsh
Aug 27, 2019Tutor
Bricked RBR50
Purchased a new RBR 50 yesterday and made the mistake of trying to update the firmware over the air. As seems to occur the router is bricked. I used the tftp method on a MacBook. The process will star...
- Retired_MemberAug 28, 2019
Ryanwalsh wrote:
I had a few good key learning points that I will try to sum up.
-It looks like it’s not very advisable to take your firmware updates over the air through the app. I’ll let the smarter folks comment there.
-There is a reasonably good help document if you search “How to update firmware via TFTP.”
-Make sure you read the firmware release notes (duh, but it escaped me.)
-Don’t forget to set your static IP address
-Store your firmware image somewhere easy to remember
-For me, the password I ended up needing to use was the one on the bottom of the router.I offer what I consider better advice.....DON"T update your FW at all. Let NG worry about that.
ekhalil
Aug 27, 2019Master
Please try to factory reset the Router and when the Router comes up, try an auto- or manual update.
- RyanwalshAug 27, 2019TutorI’ve tried a factory reset several times. No matter how long I hold the paper clip the router won’t cycle. If I power cycle the router it will flash green for a few seconds then back to red with a white flashing top light.
- ekhalilAug 27, 2019Master
Ryanwalsh wrote:
.....No matter how long I hold the paper clip the router won’t cycle. ......How do you know that it's won't cycle? When you see the top flashing LED ring, do you see the wifi SSID ORBInn on a computer? Have you tried to attach to this SSID?
- RyanwalshAug 27, 2019TutorI’d expect to see the LED near the power light go off or change. I believe the manual said to amber. There is never a change. I cannot see the SSID on my network list and cannot access it via the app. I also cannot directly access the router via Ethernet connection. I can ping the router. I can even get it to accept about 2/3 of the firmware over TFTP. I just can’t get it to complete the process without erroring out
