orbier981
Mar 23, 2019Aspirant
Bridge group to isolate traffic
I have an Orbi RBK50 router with 2 satellite, and I also have a 2nd non-Orbi wifi router. I wanted to isolate the network traffice of my IoT devices from my laptops/phones. I put the IoT devices on t...
orbier981
Mar 25, 2019Aspirant
I've read on this forum that the guest network is not truly isolated from the main network and that people have been able to access devices on the main network from the guest network, so I was hoping for an alternate solution.
CrimpOn
Mar 25, 2019Guru - Experienced User
Your memory is correct. There have been comments about the Guest network not being totally isolated. The recent firmware updates have made changes to how Guest works. It might be worth a few minutes to upgrade to the latest firmware and see if you can get access to anything on the primary network from Guest. Of course, smartphone apps on the Guest network will still control IoT devices on the primary network because they go through "the cloud", much like when they are not connected to Orbi at all.
Disclosures: (1) I don't use the Guest network feature, and (2) I'm not confident that I would know how to "prove" that Guest is totally isolated from the primary network.
