Toughguy5
Sep 03, 2021Guide
Bridge mode fog Comcast
Does my Comcast modem need to be put into bridge mode ? Right now it’s not and it’s picking up devices in my home the Orbi should be pickup. I was told by Netgear personnel to remove the bridge mode o...
Sep 03, 2021Guru - Experienced User
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
