Bmurph
Feb 06, 2021Aspirant
Bridge mode not working for CBR40 Router
Hi All, I have an issues here that I am trying to resolve can cannot figure out for the life of me. I am trying to connect the Orbi router to an ATT router. I understand in router mode this will caus...
vajim
Feb 06, 2021Master
Bmurph wrote:Hi All, I have an issues here that I am trying to resolve can cannot figure out for the life of me. I am trying to connect the Orbi router to an ATT router. I understand in router mode this will cause a double NAT and not be able to resolve traffic from ATT to Orbi. Here is what I cannot figure out. Firmware is v2.5.x up to date as of this post. When Orbi is connected to the ATT router (Obri in Router mode) after factory reset. I can see the Orbi wifi network and connect to it just fine to setup the Orbi Router. However, in order to connect to Orbi router for setup via wifi, I need to disconnect the cable from the ATT router to the Orbi router as they both use 192.168.1.x subnets (double NAT). After I connect to Orbi with the cable disconnected between ATT and Orbi, I attempt to put the Orbi in bridge mode. When I do this, I cannot connect by LAN cable (CAT5) and no wifi networks show again. I keep having to factory reset back to Router mode for wifi and device setup. Any suggestions on what to do and if I can SSH to look at some logs on the router to see WTH is going on? Thanks in advance all!
This will get you to area you which you may have already visited
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
the bigger question is why run another router with the orbi router?
- BmurphFeb 06, 2021Aspirant
Hi,
ATT is DSL and I do not have cable so I cannot use the router in the Orbi.
I have tried the KB referenced, but when I click Bridge mode (As I don't have AP mode) it does not allow me to choose an IP and automtically restart Orbi. Then, is seems to be bricked.
- vajimFeb 06, 2021Master
Bmurph wrote:Hi,
Bad purchase before doing homework
- FURRYe38Feb 06, 2021Guru - Experienced User
FYI, For the CBR40, bridge mode means that for the CBR40 it's internal router and wifi are disabled, leaving the modem portion running only which is considered modem only mode(bridged). The CBR40 is meant for a cable ISP service only. It only supports gateway mode, router and wifi are enabled or Modem only mode(router and wifi disabled.)
If your wanting to use the CBR40s wifi system, one can try this:
FYI, the top ring LED will always be ON as Pink and the front downlink LED will always blink as well.
Bmurph wrote:Hi,
