chichang's avatar
chichang
Broadcasting not working on router LAN side
I want to broadcast magic packet to a computer connected to a satellite via network cable. I verified that it works with anything connected to the wifi, and it also works from another computer connec...
  • chichang's avatar
    chichang
    Oct 29, 2018
    I have found my problem. The computer connected to router LAN side has 2 NIC and acts as a router. wol command needs to specify the right broadcast address. For example: wol -i 192.168.2.255 mac_address. Other computers or smartphones has only one IP and one broadcast address so no need for -i.
