cypma
Jan 03, 2021Aspirant
broadcasting signal to my shop - rbr50
I am wondering if any one has a suggestion for hardware that I could connect to an Orbi satelite to broadcast the signal across the driveway to my shop where an antenna could capture it and pass it t...
Jan 03, 2021Guru - Experienced User
What is the distance from the house to the garage area? Anything over 50 feet will be iffy or problematic at best. If you can run a buried CAT6a cable between the house and garage, then you can place a RBS connected via ethernet in the garage area. RBS40v would be suggested.
