cypma
Jan 03, 2021Aspirant
broadcasting signal to my shop - rbr50
I am wondering if any one has a suggestion for hardware that I could connect to an Orbi satelite to broadcast the signal across the driveway to my shop where an antenna could capture it and pass it t...
cypma
Jan 11, 2021Aspirant
Thank you for your suggestions. After reading the comments it dawned on me that I hadn't even bothered to check if there was signal in the shop. I have a medium strength signal in the shop, and using my phone I was able to get 150mb download using the xfinity speed test. The distance between the two builidings is about 65'. Fortunately the satellite sits in front of a large window and the satellite that will be in the garage will also be in front of a window. I also appreciated the suggestion to pick up the alexa capable satellite. It is much less than a rbr50 satellite.
Curt
- FURRYe38Jan 11, 2021Guru - Experienced User
Hopefully that should work for you.
