Stilts99
Jul 21, 2020Follower
Broken Orbi RBS50 Power Adaptor
I have two UK model RBS50s with broken power adaptors. Having gone through the infinite loop of frustration that is Netgear Support, can anyone tell me where/how I might obtain replacements? Thanks i...
Jul 21, 2020Guru - Experienced User
Try any online e-tailors like Amazon, eBay, etc.
You don't have to necessarily have a NG branded supply. You can get a different branded supply as long as the Volts, Amps and size of plug matches the original supply specs.
